AE-100 Connecting to DVD Player
Discussion in 'Cables & Switches' started by NJS, Apr 29, 2002.
  1. NJS
    NJS
    Yes another AE100 question, but don't let that put you off..
    I'm just about to buy one, and i'm wondering what is the best way of connecting it to a Sony 735D DVD player. I've thought about using the red,white and yellow video/audio connections in plugging into the Video in inputs.
    But can I plug them into the component in, or is there a better way to do it?
    Thanks in advance.
  2. Kramer
    Kramer
    Spend some time reading earlier threads on this issue.
    It has been gone over dozens of times.
    VGA is unargueably the best.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    "Red white yellow" - red and white are 2 channel audio, yellow is composite video - the worst quality option. Not to be confused with Component, which is a 3 channel video output. As the man Kramer says - poke around here, there's LOADS of info.
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    I think what he means is can he use the 2 phono and 1 phono lead he has got as a component lead.
    I'd think it would be okay anyone else ?
  5. NJS
    NJS
    I'm confused now. I did read previous posts but did'nt really find a straightforward answer that a novice like me can understand.
    Currently I use a cable with these 3 leads(red,white and yellow) at one end, and a SCART at the other. I was going to buy new cable with 3 leads each end and plug one set of 3 into the DVD Player and the other into the componant in. Will this work?
  6. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Yes you go from the component out of your 735 to the component on the pj :)
  7. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Right, NJS, sorry if you're getting confused. You need to be a bit careful about which connectors you plug in.
    Have a look here http://www.techtronics.com/uk/shop/50-sony-dvp-s735d-735-multi-region-dvd-player.html for a breakdown of the connectors on the 735.
    Here's a similar breakdown for the AE100 http://www.techtronics.com/uk/shop/876-panasonic-pt-ae100e-lcd-projector.html - note the connector sockets are component.
    Have a look here http://www.techtronics.com/uk/shop/510-how-to-hook-up-dvd-player.html for a summary of connection options - note that it states that RGB is not usually compatible with Component, so you may not be able to use this method, which would be a shame. Next best would be s-video, I guess.
    What you are currently connecting to your SCART is audio (red & white) and composite video (yellow). I presume this is going to your TV.
    Hope this helps - you may need to get a definitive answer re the 735's RGB socket compatability with Component input.
  8. wynouk
    wynouk
    so what connection would you advise from a dvd player component or s/vid
  9. Jonny1973
    Jonny1973
    I also have a Panny PT-AE100 and Sony 735D DVD Player.
    The best connection method available to you is to use Component Video (the red-green-blue phono sockets).
    I use an Ixos 5m 3 phono-to-3 phono lead.
    VGA is even better still but only available from a PC or DVD player with VGA out (such as Skyworth or Nintaus) and the Sony doesn't.
  10. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Perfect! Looks like you can use the component/RGB (whatever they are) on the 735 to the component on the AE100.
  11. NJS
    NJS
    Nice one :D
  12. Geoffc10
    Geoffc10
    Yes,
    Buy a Profigold component lead (£50)
    Use S-Video if you dont have component outputs on your dvd player.
    Thread Closed
    LOL
