AE 100 and HTPC route...Why?
Discussion in 'Projectors, Screens & Video Processors' started by Walter mitty, Jun 12, 2002.
  1. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Hi, I was just wondering......If I am to go down the HTPC route does it matter which projector I buy so much? I mean everyone is going for the Panny then going down the HTPC route, isn`t the picture as good on most PJ`s on this route. I rather like the Toshiba MT3 you see but changed my mind for the Panny however this is proving immpossible to purchase and it does have it`s faults too to worry about.................any thoughts from you guys?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    The only facets of the image that HTPC is going to make great are de-interlacing and scaling.
    Black level, the ability to keep black level consistent in a high and low average picture level signal, contrast, total light output, pixel count and pitch between pixels (which is one of the things that makes screen door visible), primary colour accuracy, greyscale accuracy, noise, size, ability to position off axis, ability to resolve detail before aliasing.......these area few of the other things that an HTPC has no control over but that can make a fairly hefty difference to your enjoyment of the end result....
    Gordon
  3. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    thanks for that Gordan I just can`t decide what to buy
  4. Timh
    Timh
    Sep 14, 2000
    5,257
    3
    3
    Altair-4
    +339
    Walter
    Hang on a bit longer, Panasonic might eventually get round to making the AE100 reliable.
    Oh... I just woke up!
