Advise please!
M
meridian
Hi all,
I have narrowed down my p.j to either a NEC HT1000 or a Sony HS20. I would like to know which one is more highly regarded and also does the Sony suffer from the dust build up problem I have been reading about?
Thanks,
Stephen.
K
Kramer
No problems with dust on the HS10 :).
OK, newer version of the HT1000 now available, called the HT1100.
Not a HS20 but I did compare the HS10 & HT1000 some time ago.
Have a look at the link in my sig.
HS10/20 = very high resolution while the HT1000/1100 are DLPs with higher contrast ratio & lower resolution.
HS20 is better than the HS10 so factor that into my opinion but the biggest drawback for me was (comparatively) NEC's lack of resolution.
Both different technologies so a demo is recommended. Also throw ratios to be considered with the Sonys being among the longer throw PJs currently available.
Best of luck.
:smoke:
M
meridian
Hi Kramer,
Thanks for the info. Have seen the Sony HS20 and was quite impressed with the blacks. Have not had a chance to see the NEC yet so I am unsure if r.e will bother me.
Cheers, Steve.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
