Advise on trunking cables please
Discussion in 'Home Cinema Building DIY' started by sefton, Nov 4, 2004.
  1. sefton
    sefton
    I own a philips 30PF9975 LCD and I am looking to wall mount it and truncate :confused: the cables into the wall. The wall is not yet built which gives me the advantage of building something from scratch. All the cables will go into the wall and drop about 1 metre into a cabinet which houses my equipment.
    Can anyne give me advice on how I would go about doing this in laymans terms! Obviously I must be able to remove and change the cables when needed.
    I really would appreciate your help on this one! :lease:
    ps the diagram (yes I did do it myself :blush: ) should clarify exactly what Im trying to acheive.
    Mike
  2. admay
    admay
    Mar 16, 2004
    179
    Cambridge
    +4
    If this is a new stud partition wall then you could consider using plastic drainpipe. This is easy to clip to the studs behind the plasterboard and plenty wide enough (4" diameter) to be able to easily change cables over that distance. However if it is a brick wall and plastered then you probably want something smaller.
    Andrew
