advise needed
Discussion in 'Plasma TVs' started by gazza1591, Jul 13, 2005.
  1. gazza1591
    gazza1591
    Jun 12, 2005
    72
    i have a budget of 2k to get the best plasma i can would like a 42" if posable.i would like it to be hd ready for when sky change to hd not that sure what hd is though.i have sky + but no surround sound at the moment. any recomendations ? and do the plasmas just connect to a normal coax aireal ?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,977
    2
    4
    137
    Garstang, Lancs
    +1,565
    How are you planning to mount it?
    Plamsa's with built in tuners require a normal coax connection to receive freeview, but you may need to upgrade your aerial.
  3. gazza1591
    gazza1591
    Jun 12, 2005
    72
    it will just be on a stand i think.i am haveing a new aireal fitted next week which will run just the plasma.the other aerial will run all the other tvs in the house.
  4. gazza1591
    gazza1591
    Jun 12, 2005
    72
    anyone else help with this ?
  5. nheather
    nheather
    Oct 6, 2004
    15,145
    Horsham, West Sussex
    +4,347
    Bit hard as you don't really give much in the way of requirements. However, reading between the lines it sound like you want
    HD Ready
    Sky+ Compatible for now (i.e. RGB SCART)
    Speakers (as you don't have a sound system)
    Terrestial tuner (as you mentioned an aerial)
    There are a number that will meet these. The current favourite at the top end of your budget is the Hitachi 7200.
    This is just under £2K including a pedestal stand (wall mount would be an extra £90 or so).
    The Panasonic PV500 is also aclaimed but you would be looking at £2.2K for wall mount or pedestal.
    Their is also a Samsung that is getting a lot of people excited which can be had for around £1.5K but there still isn't a lot of info about it.
    Cheers,
    Nigel
