Advice
Discussion in 'Plasma TVs Forum' started by -Jay-, Feb 19, 2003.
  1. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    I'm thinking of getting This screen has anyone got one & what do you think of it?
    I'll be useing it for Sky-dvd-xbox so what is it like with sky?
    Plus will i need a tuner & how much doe's this cost ?
    I'm new to all this so your help is needed.
  2. jmack
    jmack
    i think a few people here were looking at the samsungs not sure which one , but i think they went for the lg around the same price,
    if that is your budget i would head straight to the classifieds were some one has just put a panasonic in silver up for sale, with tuner and bracket,
  3. House
    House
    Dec 19, 2002
    571
    Essex
    +10
    A search on the Samsung should give you plenty of information.
    It basically comes as just a screen whci is PS42P2S, Richersounds price of £1995.95 or PS42P2SBX as supplied by Curry's etc with screen, tuner box, stand and speakers for £2999.
  4. House
    House
    Dec 19, 2002
    571
    Essex
    +10
    Those product numbers may not be 100% accurate :rolleyes:
  5. MARTIN TURNER
    MARTIN TURNER
    had my sammy plus tuner box since dec. very happy with it i am sure u can get a better picture but mine is perfectly adequete with dvds and sky + plus the tuner box gives me lots of options. i bet the pio and panny lot on here couldnt watch both champion league games last nite at the same time..... all 6 goals real time couldnt keep the smile off my face as mates txted me with "doh switched over and missed the arse goal". if u want perfect piccys for dvd there are better options if you want workhorse tv with bells on couldnt recommend it highly enuff.
