Advice
Discussion in 'AV Receivers & Amplifiers' started by sv1984, Sep 18, 2005.
  1. sv1984
    sv1984
    Sep 3, 2005
    187
    19
    I need to buy a Amp as in cinema sound reciver
    a 6.1 speaker set
    and some decent cables for it
    Whcih do i buy first i have a total budget of £2k. Please help me in his any good systems you have links to he sites or model numbers would be great
  2. nirmal
    nirmal
    Sep 12, 2005
    30
    Hi Sundeep,
    I dont know much about AV receivers, as I am mainly into 2 channel audio, however, for that budget, you are really spoilt for choice. You might have better response posting in the AV section of the forum. Dont spend too much on fancy cables. Good thick generic or pro cables should do the job. Good luck with your purchase.
  3. shahedz
    shahedz
    Apr 26, 2005
    10,811
    +1,707
    for £2k you can gert plenty of great amps. your money will go even further second hand, or you could save a lot buyign second hand, try the Denon's and if you want it for music as well Arcam
  4. sv1984
    sv1984
    Sep 3, 2005
    187
    19
    i need it for music and watching dvd
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I'll move this to the Integrated amps and Receivers section where it should attract more advice and interest,but as a few have already said,with your budget,you have a good choice of receivers,and you should look at spending about 40% of your budget on the receiver and the rest on speakers etc.
    You should look at Marantz,Denon,Arcam,and Pioneer as well as any others suggested,and the choice for speakers is huge.
    You will need to make up a shortlist of the best you can find,and go and try as many as you can stomach before settling down to choose.
    Don't waste huge sums of money on cables if the rest of the system isnt stunningly expensive,and even then be careful....good choices would include ixos,QED,Chord and VanDenHul as starters.
