Advice !!
Discussion in 'Plasma TVs' started by djerwood, Aug 23, 2005.
  1. djerwood
    djerwood
    I am looking at buying a Pioneer PDP-436XDE Plasma, with a Pioneer DV-585A-S Dvd player and a Pioneer VSXC502 Amp. All I need to find now is a speaker package that will finish the system off. Can anybody suggest a good package.
    I also have a question about connections. I will connect my DVD to Plasma using HDMI but what connection is best for the amp. Does the above setup sound good or would you recommend a different setup.
    All advice and comments gratefully appreciated.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    Depends on what your looking for and your budget do the speakes have to be a sub sat with a high WAF (wife acceptance factor) or dont you mind bigger boxes. Monitor audio can be had very cheap ex demo.
