Advice !!
Discussion in 'Plasma TVs' started by djerwood, Aug 23, 2005.
  1. djerwood
    I am looking at buying a Pioneer PDP-436XDE Plasma, with a Pioneer DV-585A-S Dvd player and a Pioneer VSXC502 Amp. All I need to find now is a speaker package that will finish the system off. Can anybody suggest a good package.
    I also have a question about connections. I will connect my DVD to Plasma using HDMI but what connection is best for the amp. Does the above setup sound good or would you recommend a different setup.
    All advice and comments gratefully appreciated.
