Advice
Neil Graham
Hello
Looking for some advice. I have a dated LG HT 503PH home cinema and the DVD player is failing. Its outside warrenty and not worth repair so wanted to replace it, however i want to keep the speakers as they are set up perfectly with the wiring under the carpets etc.
Can i buy a replacment LG Home Cinema Player from anywhere without having to buy new speakers etc
Neil G
Scott_Mac
Your best bet will probably be eBay as it's a fairly specialist/particular request
