Dre55
Hello
My system is as follows:
Yamaha Rxv 677
Front Speakers: Mission 702e
Centre: Wharfedale 10 cc
Sub: This is part of a Sony SS-WS5 speaker system that runs through an other amp and then into the AV, I use only the sub from that package because my Celestion went pop. I will be upgrading this to a Wharfedale SPC-10 Sub very soon.
Rear Speakers: Wharfedale WH-DFS.
Room size is: 16ft x 12ft
Question is I would like to try a set of side speakers and can lay my hands on a pair of Jamo A102's but these are 6ohm. Would it cause me problem with the other speakers that are rated 8ohm or with the AV and if not where is it best to mount them. Do I move the bipole speakers to the sides and put the Jamo speakers to the rear or keep the bipole where they are.
Thanks for any advice that is forth coming.
Yamaha Rxv 677
