T
Tommo1975
This is my first post on the forum. I have recently upgraded some of my AV kit and wondered if anyone had some good advice as to the best speakers to suit the rest of my setup.
I have an Arcam AVR300 amp and I am playing my music through either my Arcam DV79 player on direct into the AVR through my ipod.
At present I am using a pair of Eltax floorstanding speakers which I bought about 5 years ago for about £250 I think. I also have a KEF centre speaker http://www.hifibitz.co.uk/product.asp?id=3251 and a pair of Celestion AVS 101 surrounds http://www.celestion.com/products/soundstyle/avp100specs.html
I think it is worth replacing the fronts with some new floor standers and I am debating about relegating the old Eltax units to the role of rears when I do this.
Can anyone offer some advice as to what I should go for, my budget is about £1,000. Also has anyone got any experience with the AVR300 receiver/amp and if so what settings should I be using the unit with when playing back audio CD's? Should I bypass all the EQ settings and just use the direct button on the amp?
Thanks in advance for any advice.
Kind regards
Mark
PS: I forgot to say, I also have a KEF active sub, don't know the model name but it's a square cube
Kind regards
Mark
