Advice. Which wall mount?
Discussion in 'Home Cinema Buying & Building' started by stormjai, Nov 27, 2003.
  1. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    Getting a Pio 434. Need wall mount.
    Anybody know a good fast supplier of decent ( Unicol) wall mount non-tilting
  2. nealgs
    nealgs
    check out the AVForums Powerbuys section - universal wall mount 18mm deep - have one for our panny 433MXE
    under £130 delivered - great bracket (as brackets go) :)
    Gary
