Quantcast
advice wanted on speaker package
frankie13
what speaker package should i get to go with my ptae100 projector my screen size is 8ft across 5ft down any ideas m8s
my amp is a panasonic SA-HE9
C
cyclops12
ive just bought some logitec z 680's only £220 they have dts+dolby digital+dolby pro logic 2 decoders built in also they are thx certified . 505 watts rms out put the sub is 188 watts rms and makes the room shake you can plud 4 things in at once!! they have optical and jack digital inputs along with 6 channel descrete inputs if u are on a bujet i cant recommend enough!!!:smashin
also ive got a technics seperates home stereo witch is dolby pro logic and these speakers sound better hope this helped good luck
