Advice....surround sound from cable tv??
Discussion in 'Home Cinema Buying & Building' started by paultrfc, Aug 20, 2004.
  1. paultrfc
    paultrfc
    Aug 20, 2004
    20
    hi i am thinking of getting an all in one home cinema dvd (Samsung HT-DS400 DVD) or any similar
    can i connect my ntl set top box to it so i get the sound through the speakers??
    and also can i connect my x box to it again to get sound through speakers..
    cheers for any help.... :)
  2. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    yep, got my ntl box and xbox connected up to my amp.
    You will need to get a reasonably decent all in one is suspect that has all the right connections at the back. You will need an optical input for the console ideally and a couple of analogue stereo inputs for the ntl box
