Advice Sought: PCI 1680/1050 60hz compatible graphics card
Discussion in 'Desktop & Laptop Computers Forum' started by ap69, Dec 21, 2006.
  1. ap69
    ap69
    Jan 28, 2005
    430
    +15
    Hoping some one can help with some graphica card advice.
    Have purchased a new 22" monitor with 1680x1050 resolution, but my current (rather old) PC cannot display the required resolution.
    My motherboard is a GA-7VAXP Ultra
    http://tw.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1595
    Can anyone recommend a graphics card that will give me the above output, that is PCI (and if possible offers DVI as well as VGA)? Is a temporrary solution until I get a new PC, so should be cheap if possible and would consider 2nd hand.
    Many thanks for any help
