Advice Sought: How to Link a Digital Radio to Wireless/Uncorded Earbuds
Discussion in 'Headphones, Earphones & Portable Music' started by Nidger7, May 2, 2016.
  1. Nidger7
    Nidger7
    May 2, 2016
    2
    cheshire
    We are looking for guidance on how to listen to a digital radio (Roberts Dreamtime ver1) via either a single or twin uncorded/unwired earbud type earphones.
    This is driven by a need to use at night and to avoid the possibility of getting tangled up in the wires.
    My limited understanding is that I may require a Wireless Bluetooth Audio Transmitter which is then paired with a compatible set of earphones.
    Any advice on suitable manufacturers/equipment would be greatly appreciated.
    Many Thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    22,725
    Lanarkshire
    +2,396
  3. Nidger7
    Nidger7
    May 2, 2016
    2
    cheshire
    Many thanks for your quick response; I have had a look at proposed solution and it appears to be exactly what I need.
    Regards
