A
avbeginner
hi, first post so go easy...
just purchased my first av system, blew the budget with denon 2910 dvd, denon 2105 amp, and infocus 4805 projector.
using a 10m dvi cable from the dvd to the 4805, and a coax cable between the 2910 and the 2105.
sound is great, picture is almost there just need some fine tuning. but where do i start? putting the system through its paces with the hulk - gave odd shadowing / blurring of the clouds in the fast moving scenes eg escape into the desert. the sky can also look a little grainy at times.
the dvi settings of the dvd include 480p/720p and 1080i which to go for?
am i getting poor picture because of the length of dvi cable?
or should i be concentrating on the projector settings?
thanks in anticipation of your kind help....
(before you ask I carried out a search, but it did not help)
