advice required on setting up Pioneer 868
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bristol Pete, Mar 13, 2005.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I have just hooked up my new 868 to my SIM2 30H via HDMI.
    Any suggestions on the best performance? ~ I pressume that 720 is that way to go with the SIM2 set to pixel to pixel aspect ratio?
    Or, should I consider 1080i? :confused:
    Thanks.
    Captain Benefit.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Seeing as no Sim2 owners have popped by :) .. with my H77 720p is far better than 1080i. The higher res. produces a softer image, presumably due to inherent softening imparted by up-scaling not being countered by the down-scaling in the projector.
    Obviously I'd expect a Sim2 to have a superior scaler to the H77 so it may be different with that beast.
    Oh yes ... it's a LOT better feeding 576i via HDMI into a Lumagen scaler. ;)
