advice required on painting a screen. Urgent!
Discussion in 'Projectors, Screens & Video Processors' started by Bristol Pete, Dec 23, 2004.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    After moving home this year I lost my dedicated cinema room so I subsequently sold my electric screen :mad:
    For now I am projecting onto a magnolia wall, this seems ok but I have decided to paint it.
    Can somebody remind me of which colour would be best?
    White, sliver etc and what type of paint - i.e. matt, silk etc.
    Thanks,
    Cap :smashin:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I just painted my MDF fixed screen with matt brilliant white, works a treat. Dulux Icestorm 5 and 6 seem to be very popular, think 6 is almost white, 5 a little darker (but may be the other way round ;) ).
    Good luck!...PJ
  3. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Hey Cap,
    I did have a white painted screen however i found that it did not help the black levels, so i brought some Ice Storm, small tins, 1 x 6 and 1x 5 shade and mixed together and what a result, pictures look great, took some pics with a half white and a half grey screen, difference is clear to see. Anyway paint is cheap so i would suggest trialing various colour to see which suits your set up best. Sorry forgot to say the screen is matt.
