ADVICE required...either Sony KV36FS70 or Tosh 40WH08B
Discussion in 'General TV Discussions Forum' started by Fagin, Nov 30, 2001.
  1. Fagin
    Fagin
    Anybody give me advice on which to purchase, with pros & cons.
    I will be using the set as the main living room TV, and at the moment have a 33" 4:3 Tosh, which I am very pleased with as far as the picture is concerned, but really want a big widescreen. The set will used for SKY viewing, DVD and game consoles.
    Which is the best bet??
    Thanks.
    Shaun.
  2. Fagin
    Fagin
    BTT
  3. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Go for the Tosh.
    I've just bought the same model and I well pleased with it.
    DVDs and games look awesome on it.
    Analog looks OK and is often better than digital. It depends on the channel, signal and your provider.
    You'll get a MUCH bigger picture with the Tosh, especially when viewing 4:3 pics.
