Advice required.. 4 flats need sky whats the best way??
Discussion in 'Sky Digital TV Forum' started by Splash, Dec 21, 2004.
  1. Splash
    Splash
    Dec 21, 2004
    165
    +25
    Live in a house converted into 6 flats, 4 of the flat would like to get Sky.
    The trouble is the house is a listed building so we can't plonk dishes on the front. We could put a dish on the back but the owner (quite rightly) does not want 4 dishes on the front of his flat. So we are looking to run 4 subscriptions off one dish. I spoke to Sky and they pointed me in the direction of some subcontractor who was not really interested (as only 4 flats) and quoted 1000s for a communal system.
    There must be another way?? I've seen that you can get 4 LNBs on a dish... will sky do this if pushed or is there another option??
    Can't get cable b4 anyone suggests it!
    Ta!
    Splash (Leamington)
  2. knoxville
    knoxville
    wouldnt freeview or topup tv be any good?
  3. Splash
    Splash
    Dec 21, 2004
    165
    +25
    Nah we all want the footy/cricket/movies etc etc. :clap:
  4. knoxville
    knoxville
    i think you can do it! you can either do it buy hiring 4 boxes and splitting the signal OR get sky to install it themselves having the four LNB's off one dish. It IS possible.
