advice request for hooking up dvd sky and tv
Discussion in 'Cables & Switches' started by LexLD, Dec 13, 2004.
  1. LexLD
    LexLD
    Hello
    i have a sky digibox (amstrad version) a logik tv and just got a bush dvd player that i want to add into the skybox/ TV system and not entirely sure the best way to do this.
    do you scart cable the dvd to the digibox, then scart tv to digibox in a chain, and then do i need to get more rf cable to connect up the tv and dvd player or what? all manuals happily bang on about hooking in amps, speakers, half a dozen other components, but none have instructions about adding into sky box!
    any help appreciated as i'm terminally blonde where all this stuff is concerned.
    LexLD
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    as you suggest just need to looop DVD through Sky box DVD>SKYVCR scart: SKY TV SCART> TV no need for RF oranything else...... set both RGB and away you go....
  3. LexLD
    LexLD
    thank you - i'll give it a whirl and be back if it doesn't work!
