Advice regarding Panasonic TH-50PHD8E
Discussion in 'Panasonic TVs Forum' started by davsdu, Sep 14, 2005.
  1. davsdu
    davsdu
    Feb 13, 2005
    183
    +3
    I got a good deal on a Panasonic TH-50PHD8E.
    And now for a question: I guess I only need a HDMI input-board, if I purchase a scaler as well? (thinking about the new one from DVDO). I'm planning on connecting my digital tv box to the scaler using scart, connect the dvd-play to the scaler using SDI (HDMI untill I actually get the upgrade), and connecting XBOX360 (when it comes) by the best possible way.
    I see that you can also get a SDI input board for the screen, would it make any sence to get one of those, since the DVDO scalers can only input SDI and not output it?
    I'm living in Denmark, but buying the screen from Germany - but the screen is covered by Panasonics European Warranty, right?
    Any other usefull information I should be aware of?
    Thanks in advance!
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    hdmi should be all you need. The vga port also does component. I dont think the sdi board is any good to you, just send the scaler an sdi signal and output through hdmi
  3. davsdu
    davsdu
    Feb 13, 2005
    183
    +3
    Thanks for your answer!
    VGA costs extra, right? Would it make sense to use VGA when I can use HDMI?
  4. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    vga wont cost you any extra, its built into the panel. They all come with a vga port built in
