Advice re: suitable bulbs for an X10 lighting system
Discussion in 'Home Cinema Buying & Building' started by cerebros, Jan 16, 2005.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    Hi all,
    Due to renting I'm looking at X10 at the moment to control some lamps and room lights via my Pronto
    However, I'm a bit confused as to which bulb types are suitable for use. I've been looking at the LM15's Simply Automate and the description down the page says:
    Yet Marmitek (X10's manufacturer) say in their brochure:
    So which is correct? What are the problems/risks (if any) of using low-energy bulbs with these X10 lamp modules?
