Advice re setup of 3802
Discussion in 'AV Receivers & Amplifiers' started by Trig, Jul 28, 2002.
  1. Trig
    Trig
    Dear all,
    Have recently purchased a Denon 3802 together with B+W's DM602s3 fronts, LCR60s3 center and DM600s2 rears.
    My question is, what size to specify the speakers in the setup?. I do not at the moment have a sub. The menu seems to default the size setting to large fronts when no sub is selected, is this the correct setting?.
    Yours Novicely,
    Trig.:blush:
  2. bob007
    bob007
    Yes. All the bass is directed to your fronts.
    Only when you connect a sub can you go into the amps bass management menu and select other options, speaker size and crossover etc.
    Bob
  3. Trig
    Trig
    Thanks for that Bob.
    While you're on......... if at some point I do connect a sub, will the 602's be a large or small speaker in the menu ?.
    Thanks again:)
  4. bob007
    bob007
    If it were me i would select small, crossover 80hz and send bass to the sub.
    Best thing to do is when you have a sub is to select which sounds best to you, think you will find most select small.
    When you start looking for a sub, stay on the same track as the system you have put together so far, Uncle Eric will steer you in the right direction, have a look on the Power Buy Forum. ;)
    Cheers Bob
  5. Trig
    Trig
    Ta !:)
