Advice re: celling mounting 24inch LCD
snazpizaz
mikej
Will you be able to locate a ceiling joist to mount the bracket to ? That will give you the most secure way of fixing it to the ceiling.
I was also going to suggest M4 bolts, judging by your photos and the size of the TV. I would buy a bracket that comes with a selection of different size (and length) bolts, washers and spacers.
MSW
I would buy 2 pieces of 60cm x 40cm x 2cm piece of chipboard
Find the joists - they will be roughly 60cm centres apart
Screw the chipboard (One on top of the other ) to the ceiling joists then you can pretty much use anything to fix the TV mounts to the chipboard
The extra 4cm space from ceiling to TV that the Chipboard gives you will help with fixing cables etc
snazpizaz
hi - thanks everyone so far.
1. I'm not worried about ceiling joists because it will be fixed to a large, solid overhanging wooden shelf and the tv is small sized.
2. RBZ5416 has identified my screw holes as VESA 75 x 75 (Thanks!) which i take to mean bolt-hole centre to bolt hole centre. Do you think i could fit this :
onto this:
Ceiling Roof Wall Mount TV Bracket LED LCD Swivel Tilt Holder 14-37 inch Monitor 720562348425 | eBay
to convert the ceiling mount so it takes VESA 75 x 75 ? Is that a common type of work-around route to take ?
cheers again folks
RBZ5416
Do you think i could fit this onto this.
Possibly, but I think that's really intended to go larger rather than smaller. There still won't be holes at 75mm in the ceiling mount so you may need to be creative with how it all goes together. You may also need addition M4 bolts as it's not stated exactly what's included with the ceiling mount. Although it does say "All screws to go into the back of your TV".
Better to find one that supports 75mm directly, maybe this?
Podcast: REL T/9x Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
