Advice please
Discussion in 'AV Receivers & Amplifiers' started by Davee1234, Feb 9, 2009.
  1. Davee1234
    Davee1234
    Jan 5, 2009
    3
    Wickford
    Looking for advice
    I'm not an expert at all...!!!! but I've been looking for a decent amp for my Sumsang 40" plasma. I've considered the Yamaha DSP-AX863SE, and have left a order with a site, but it appears that none are coming into the country for a couple of months. Had another look around and looked at the Sony STR-DA2400ES.
    I intend to hook up Tannoy 611's (MK1's) at the front and Goodmans Maxim II's at the rear. I have a B&O sub woofer. Then I just need to get a decent centre speaker and the cables (looking at QED's for this)
    Are the amps a good choice, and would you recommend anything else around the £500 mark also would it work with the speaker package I have? All comments gratfully accepted. Thanks
    Dave.
  2. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    also take a look at the denon 1909, richer sounds has them at £299 and alot of people rate them!
  3. Davee1234
    Davee1234
    Jan 5, 2009
    3
    Wickford
    Thanks for taking the time, I'll get reading the reviews right away.
    Dave.
