Advice please
Discussion in 'AV Receivers & Amplifiers' started by AndrewC, Mar 12, 2003.
  1. AndrewC
    AndrewC
    Mains small or large? LFE High Cut level?
    My setup:-
    Sony 1070
    B&W 603's, 601's CC6 S2
    Velodyne CHT-10
    Cheers :)
  2. Grimley
    Grimley
    The usual reply here is set your main speakers to small, LFE cutoff on A/V amp to 80hz (90 in your case assuming its the same as mine, I have a Sony 940) sub cutoff on max.
    IMO tweak the settings on your system until you find the settings you like best.
