I am intending on videoing some cars in action at an airfield...I have a budget of between £700-800 to spend...there will be inside the car action as well so I would presume a stablizer would be important as well as decent audio for engine sound etc...
I understand digital is better quality than analogue but I presume they both use tapes.. so am I right in thinking that when you connect it to your PC you cant just download the video from memory it still has to come off the tape ??
It would be great if there was a clear choice of camcorder in this price range..but I could go a liitle more if there was something outstanding which is a bit more...
Jabba
Jabba
