Advice Please !!!!!!!
Discussion in 'Subwoofers' started by hickmeister, Mar 25, 2006.
  1. hickmeister
    hickmeister
    Mar 4, 2006
    198
    I need to buy an Active Subwoofer, but on a very tight budget, would like it to have high and low level inputs, dont want anything special.
    Budget - Under £100 :eek:
    Can anyone point me in the right direction ???:lease:
    Just looked at this one below. WIll this do the job ??
    http://www.hifibitz.co.uk/product.asp?id=5264
  2. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    I know it's not what you want to hear, but you really need to up your budget a bit, these are both excellent subs:
    http://www.bkelec.com/HiFi/Sub_Woofers/Minotaur.htm
    http://www.bkelec.com/Special_Offers/sp8.htm
    Be far bet than that Wharfedale, which I really wouldn't expect to be upto much, you'll be glad you spent the extra.
    Or if £100 really is your very limit then have a look on Ebay, but to be honest there haven't been any real bargains for a while that I've seen.
  3. hickmeister
    hickmeister
    Mar 4, 2006
    198
    Thankyou for your reply, i know the budget is a bit low i will have to see what i can do.:suicide:
    Just Looking about and came across this one
    http://www.hifibitz.co.uk/product.asp?id=2790
    This has had some good write ups, and is available from comet for £79.99:clap:
    Has anyone got one of these ?????
  4. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    At £80 it's probably ok, I'd still think you should try and scrape together the extra for one of the little BK's, they're essentially the same sub as the multi award winning MJ Acoustics 50 Pro, which cost twice as much:
    http://www.mjacoustics.co.uk/MJ_Acoustics_Wesbite/Products/Pro _Range/pro50.htm
    The sony will be fine if all you want is something to make a nice boomy noise when there's an explosion on screen.
    If you get it then report back and let us know what you think of it, it may be a little gem for £80.
  5. hickmeister
    hickmeister
    Mar 4, 2006
    198
    Just Ordered the Sony Subwoofer, hopefully should do the trick.:thumbsup:
    Will report back :smashin:
