Advice please
Discussion in 'Photography Forums' started by stingray, Jul 29, 2004.
  1. stingray
    stingray
    Jul 8, 2004
    I have been looking at buying a digital camera just for mainly taking pictures for use on ebay and the odd holiday snap, I have been looking at the Kodak 6200 which I have seen for £67.
    Is this worth having or can anyone recommend me anything cheaper?
    Thankyou
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    If all you need is a camera for putting pictures onto web sites then you only need something very basic like the camera you are looking at!
    If however the occassional holiday picture will be printed, rather than just viewed on screen then you will need to spend a bit more to get anything close to good results.
    Mark.
  3. Gibber4
    Gibber4
    Try here to compare photos of different cameras.
    http://fotopic.net/community/cameras/
    I use a kodak cx4210 for ebay and it does the job and now i have sorted out the problem with the focus i get good photos outdoors considering the specs.
    You can pick one up for about £60 on amazon.
