Advice please.
Discussion in 'Blu-ray & DVD Players & Recorders' started by mxs, Jan 11, 2004.
  1. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    I am toying with the idea of buying a DVD recorder.
    Is there such a beast on the UK market that reads and records on both '+' and ' - ' discs?
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Yes, and if you do a search of the forum you will find long threads about them and their merits or otherwise
  3. PhilipL
    PhilipL
    Jan 18, 2002
    3,839
    103
    +442
    Why do you need to record to both formats?
    What benefits do you think you would get by having support for both on the recorder?
    If you answer these then it will be easier to advise what options might be best for you.
    Regards
    Philip
