Advice Please...Which LCD
J
JohnEEEboy
Hi guys
Im new to this site and pretty new to the modern range of LCD Tv's
Im looking for some guidance and recommendations on which Tv to buy.
I have a budget of £2000 and am a bit overwhelmed by all the choice and tech speak.
I would appreciate your thoughts, but please keep it simple.
Thanks guys:smashin:
psikey
You'll need to let us know size of screen you want & what you will be using it with i.e. PC, console, SKYHD etc.
J
JohnEEEboy
Probably 37" screen........not too bothered with Sky
psikey
Well I'm very impressed with my Sony 32V2000 for SD, much better than Samsung and the 40V2000 is under £2000 but a Plasma may be better. See what others recommend.
PS the 32V2000 looks to have won EISA best LCD 2006/2007 :thumbsup:
J
JohnEEEboy
S
shirtee
How about going large and getting 42" Panasonic Viera. It's PDP but damn it's good...
J
JohnEEEboy
I had thought about a PDP but the screen burn issue, running in, and what I had heard from others put me off:(
