Advice please ! which LCD ?
Discussion in 'LCD & LED LCD TVs Forum' started by conkernuts, Nov 12, 2004.
Tags:
  1. conkernuts
    conkernuts
    I,m buying an an 32" LCD and it's between, Sony KLV-L32M1, Philips 32PF9986 and Panasonic TX32LXD1, any advice please ?
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Go and view them in person and make sure that the pictures have at least been basically calibrated from the factory settings. View them on a good DVD (not an animated film which always look good) source and a poorer quality source also, such as their analogue and/or inbuilt freeview tuner and if you have $ky, from a $ky source too viewing a number of channels.
    If you intend to connect any source via a digital connection (DVI/HDMI) make sure you see it work paired with the exact piece of kit and at your preferred resolution / aspect ratio setting and with a range of copy protected PAL and NTSC discs.
    Then make sure that the sets will accept the various inputs that you intend to use both now and into the future.
    -Ian
