Advice please, should I add a Sub or Change my Tannoy Front Speakers ???
Discussion in 'Subwoofers' started by Taz69, Jan 3, 2004.
  1. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    Hiya all, I am thinking of a upgrade:
    I currently have:
    Panasonic 36" W/S TV
    Toshiba 330e M/R DVD
    Marantz SR4200
    Tannoy 633S Floor Standers Fronts (sat about 3ft away from the tv due to no shielding)
    Morduant Short 905centre
    Morduant Short MSB20 Bi-Polar Rears
    I watch Movies on DVD aswell as listen to Music
    I am looking to either upgrade the fronts or should I add a Sub, I was thinking of the Mordaunt Shorts 904's ???
    Any advice welcome, please.
    Taz
  2. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    If you like the Tannoys then I would get a sub as you are unlikely to get what a sub will give you from Floorstanders. IMO
  3. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    Hi m8, I like the sound of the Tannoys, I find them a hassle to place thou as no magnetic shielding.????
    Taz
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Unless you go to the expense of proper full range speakers(and to get down to 20Hz is seriously expensive in terms of speaker systems),a sub is the single quickest,best and cheapest upgrade you can make to your system.
    Your only problem then is to decide on which sub,and there are loads of people here who'll give you advice on that...choosing the right one,i.e.one that works well in your room,is critical,and once you've shortlisted a few in your price range,get as many as possible on home demo before deciding.
