My Desktop PC needs a replacement motherboard due to heat-damage behind the Processor socket; the board is noticeably bowed and distorted. The processor itself (Pentium P4 3Ghz) is working fine; as is the rest of the machine. The op.sys (Win XP home edition) was already pre-loaded loaded onto the desktop when it arrived new and has not been re-loaded since. I have the original Product Recovery CD-Rom and the original product key/sticker number.
I have purchased a second-hand replacement motherboard of the same spec/manufacturer as the original. When the replacement motherboard board has been fitted and the other components transferred (P4, RAM etc) could any of you clever people tell me what procedure I need to follow to get the Desktop back up and running without compromising the data on my hard-drive. There are programmes on my drive that cannot be recovered.
Thanks & regards in anticipation.
