Advice please panasonic 42pw7
Discussion in 'Panasonic TVs Forum' started by davebmw, Feb 24, 2005.
  1. davebmw
    davebmw
    thinking about buying pw7:to display ps2,pc,and ntl cable anologue tv rf cable from it,can someone plz advise what i need to connect ,also what picture quality im likely too get,plz keep it simple cos im as daft as a brush .cheers dave :confused:
  2. Tarsh
    Tarsh
    Jan 9, 2005
    52
    9
    Essex
    Have a read through this thread, although it was based on the PDW6 it contains a lot of useful information and is fairly current at the end.
    http://www.avforums.com/forums/showthread.php?t=154292&highlight=beginner
    It's quite long, and your head may spin with all the info, but make a start then come back and ask any further questions you will undoubtedly have :)
    Good luck :smashin:
  3. Simon James
    Simon James
    dave are you running through an av amp? Do you have a freeview box?
