Advice please on recording digital tv
Discussion in 'General TV Discussions Forum' started by teddyt72, Oct 25, 2004.
  1. teddyt72
    teddyt72
    We have bought a Sony KD-28DL10 U Digital Tv with a matching sony VCR and DVD player. we are having problems recording Digital TV. When we have it on analogue it's fine, we can record no problems. However when we put it onto digital to record the recording goes blank if we turn the Tv off. Is this normal and is there a way to stop this? We also can't change channel if we are recording digital, again, is this normal?
    Thanks in advance for any help.
    Eddie.
  2. Bender
    Bender
    Feb 3, 2004
    93
    9
    Manchester, UK
    I think the answer is yes.
    Your IDTV only has 1 digital tuner which becomes a problem if you want to record one digital channel and watch another. Your VCR only has an analogue tuner, so taping analogue programs is fine but it's using the one and only digital tuner in the tv to tape digital channels, hence turn of the tv and it looks like the digital tuner is also turned off.
    The only way around this I'm afraid is buy a separate digi. box if you want to be able to watch a one digital channel while recording another.
  3. Contact
    Contact
    Oct 17, 2004
    64
    All true. Manufacterers are inexplicably dodging putting digital tuners into their VCR's. It looks like DVD Recorders are the only possibility for that.
    I spoke to a Sony rep not too long ago, who assured me Sony were in the process of getting a DVD Recorder ready, but the new range is out now and there's been nothing. For the time being, you'll indeed have to link a seperate digi box straight to the video to act as its own seperate digital tuner.
  4. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Your tv and vcr have a feature called SMARTLINK -
    Essentially, you can use the tv's own 7 day epg to pick a program to record from it's digital tuner and the tv will tell the vcr when to record.
    This method is very simple, and doesn't require you to leave the tv on. If you do switch the tv off, and it is waiting to record something - the digital tuner part of the tv switches on and over to the correct channel to be recorded. If the tv is on and you forget that you'd set the timer earlier, and try to switch digital channels - the tv reminds you.
    Refer to your owner's manual for more info.
