We have just had our living room re plastered. We bought a marble fire surround on pre loved and although it looks stable, what glue would you recommend to stick it to new plaster. Any advice please would be welcome
If it's made up of two pillars and a mantle then silicone sealant would be ideal. We used it on our old granite fire surround and as well as giving good adhesion it also has flexibility so it doesn't become brittle.
HI, when we had our house replastered we sort of went a bit simpler with just granite base , cast iron gas stove and a faux old mantle . Might have to get the gas input hid away though. Easy to put up , the base is floating and held down by the weight of the stove.
