Advice please for buying new LCD TV
Discussion in 'LCD & LED LCD TVs Forum' started by BenK1980, Jan 3, 2007.
Tags:
  1. BenK1980
    BenK1980
    Please could someone provide me with advice, I am seeking a TV with the following spec:
    LCD
    32inch - 37inch
    HD
    Widescreen
    Will not be using speakers much as I have surround setup, so sound is not important.
    Don't care about built in freeview, VCR or DVD.
    Will be hooking up amp, sky, xbox 360, ps2.
    Don't think I need/can fit much more than a 32 inch TV in my flat.
    Looking to spend around £500 - £800, could spend a little more if really worth it.
  2. Mr Cole
    Mr Cole
    Dec 4, 2004
    352
    Birmingham
    +12
    A good choice would be the Panasonic TX32LXD60 which I think can be found online for around 700-800 pound mark. It also has 2 hdmi connections too which are good features if you're looking to future proof as much as possible.
    I have the 26" version of the above and a slightly older model 32" as well and have to say I'm more than happy with both.
    Samsung's usually come in pretty cheap but personally I was always disappointed with the sound quality.
    I'm sure you'll get some more recommendations from other members, it seems the Toshiba's are pretty popular too and are well within your budget.
