tankrocco
Hi - First post looking for some advice so be kind
Currently have a 5.1 setup, with Dali Zensor 1s as fronts and mid, cambridge audio minx at the rear driven by a YAMAHA-VX483 amp.
I'm currently running a Cambridge audio SX-120 FF 8" sub, which is fine but looking to upgrade to a 10 or 12" for more power. Mainly will be used for gaming, movies and music so a mix really. I've been an admirer of BK subs for a few years now and looking at either the BK Gemini II or P12-300SB-DF as I don't have a sky high budget and impressed with the value they seem to deliver! Wondering though if the P12 will overpower my setup and whether I should just go with the Gemini?
Room layout is below:
Any advice would be much appreciated!
