Just so we are clear - STEREO? Right?
Dali Zensor 7 are currently £500/pr which is an excellent price as they are typically £730/pr
. That leaves about £800 for the
Amp/Receiver and
CD Player.
Dali Zensor 7 Speakers (Pair) - Superfi
At this point we have to set priorities. Most often I would recommend Amp and CD at a similar price. So, in this case, about £400 each.
But the
Yamaha RN802 Network Receiver, 100w/ch, DAB/DAB+, Network Streaming 2xDAC, Room EQ, Full Bass Management is about £570.
Yamaha R-N803D Network Amplifier
That leaves only £230 for the CD Player. Now you can get a decent CD Player for that kind of money, or just a bit more.
The
Yamaha CD-S300 is about £200.
Yamaha CDS300 CD Player
The
Yamaha CD-S700 CD Player is about £400 -
Of course, plenty of other
CD Players to choose from -
CD & SACD Players - Separates - Hi-Fi
Here is a
B-Stock Yamaha CD-S700 CD Player for £250 -
Manufacturer Refurbished - Yamaha CD-S700 - Black - S/N: 97932
Likely this is a One-Off
(one of a kind), though possible they may have more than one.
This
Onkyo and this
Marantz are also worth checking out -
Onkyo C-7030
Marantz CD6006 UK Edition
The
Marantz CD6006-UK has a pretty solid reputation as a CD Player.
Keep in mind that most
BluRay players will also play CD. Though with the lower cost models, you will not have Analog connections so you will have to use Digital. Which is fine because the
Yamaha RN803 has 2xOptical, 2xCoaxial, and 1xUSB-Media inputs.
If you will use this for movie watching, and if you will have a
BluRay Player, then that can double as a CD. If you are satisfied - fine. But later if you feel you need more, then you can buy a CD within your new budget.
£500/pr = Dali Zensor 7
£570/ea = Yamaha RN803 Network Receiver
£285/ea = Marantz CD6006-UK CD Player
£1355 = Total
Not exactly right on, but close to your budget
£200/ea = Yamaha CD-S300 CD Player
£1270 = Total
Which is very close to budget.
The
Yamaha RN803 is stretching your budget, but that is a lot of amp with a lot of features.
There are other options, but give this some thought and see where it can be revised.
Steve/bluewizard
