Advice on wall mounting a LCD Television
Discussion in 'Home Cinema Buying & Building' started by psychedelic, Mar 20, 2005.
  1. psychedelic
    psychedelic
    Nov 27, 2004
    30
    Edinburgh
    Hi Guys, I recently bought a flat which will be ready by the end of May 2005. I am planning to wall mount a lcd tv in the lounge. I am just wondering if anybody has put wires in the walls during the construction stage so that it appears cable tidy. And what would be the usual height for installing a 32 inch tv. Also it would be helpful to know what kind of precautions I have to take.
    Thanks for the advice
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    psychedelic, you should do a few searches on this forum for 'wall mount', 'correct height' etc. These topic's have been covered plenty of times before.
    Jud
