Advice on viewing distance please
Discussion in 'Plasma TVs' started by chris4817, Dec 14, 2004.
  1. chris4817
    chris4817
    I have been looking at this forum for sometime now and have found it invaluable.
    I am hoping to buy an Hitachi 42PD5300 in the New Year. My living room is not big and I will sit about 9 feet from the screen.
    I notice on the forum the other day that another member was thinking about buying the 37" as he would only sit about 8 feet away.
    Can anyone advise me whether I am not sitting far enough away to properly appreciate a 42" and whether I would be better off with the 37"?
  2. mpadgett
    mpadgett
    I have a 42 inch plasma, i sit about 8 feet away. just perfect i think
  3. chris4817
    chris4817
    Excellent. Just the answer I need, thanks!
  4. banjo21
    banjo21
    Oct 3, 2004
    1,552
    63
    Wirral
    +127
    yep - go 42".
    Silly me went for 37" at only 8 to 9 feet away a couple months ago.
    You just dont realise how small the overall 'footprint' of these thin screens are and the effect is that the set looks smaller than my old 28". I wish i'd gone 42 - do it - if its too big I'll swap with you :)
