Advice On Upgrading Please....
Discussion in 'Home Cinema Speakers' started by LDR, Apr 1, 2002.
  1. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    I am looking to upgrade my speakers & possibly a subwoofer..currently have a Toshiba 32" Dolby Digital TV with built in subwoofer, & 2 external front speakers & two rear surround sound speakers...What should I be looking for to improve the all round sound in my room..it is approx 17 foot by 15 foot...
    thanks...
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Better speakers will improve the sound a little but to get a real improvement you will have to buy a separate AV amp as well.
    Quoting a budget is always helpful.
  3. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Yep..see what you mean..........was considering either the Sony Str-DB1070 or possibly Yamaha RXV620RDS..anyone got opinions on these ?? Or should I be looking at something else..dont wanna spend more that £400 on an amp...
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Both amps have their followers but I think that most unbiased people would probably go for the Yammy.
    For speakers you should be looking at buying my set up as advertised in the classified section.:clown: :clown:
