Matt 0987654321
My brother always comes to me for AV advice. This time he is looking to change his Panny 50’’ plasma.
He currently watches Netflix through the PS3 but tells me this no longer works. He has a large sitting room but I think 65’’ would be too big. Anyway he had seen a review of a Panny 65 OLED and was thinking of buying.
I suggested an LG 55 CX as he will get and extra 5 inches with minimal outer frame dimension increase to what he presently has.
The only issue and what is making me reticent to recommend is that he only has an internet link provided by vodaphone and a terrestrial antenna.
His link to the WiFi hub isn’t great. He does not want Sky (who does!) or Virgin. So boosters may be on order.
Are there better ‘connectivity wise’ TV’s then LG, can LG do all the on demand catch up services? Even though I have LG I watch catch up thro the V box. Is Sony an option, they seemed to be mentioned alongside the LG’s.
If 65’’ is the preference is the Panny HZ 65 2000B the way to go, it gets good reviews but it seems expensive. He could save £1800 and get additional gear.
Any advice is appreciated.
