Chivas2973
I live in a house that has a living room with a TV over the fireplace in the corner of the room. Behind this TV are Audio Out Speaker ports in the wall, 5 speaker + and - and a Subwoofer. This goes through the wall into a closet in another room where a receiver should be. There are banana plug connectors out to the receiver from the wall. There are another set of plugs also to go from the receiver to the 5 speakers in the ceiling and a subwoofer. I am looking for the cheapest simplest way to get sound from the firestick to all 5 speakers and subwoofer. I know this is hard to hear for some, but I don't care if the sound is perfect. An ideal situation would be 5.1 surround sound but I would be fine with just stereo to all 5 speakers and a subwoofer. I don't need multiple inputs for radio, DVD, CD, blah blah blah like I used to. I simply need one input, my Amazon fire stick. I think the easiest setup would be something that can receive bluetooth from the firestick and transmit wired to 5 speakers and a subwoofer but everything I find is either a very expensive receiver that is complete overkill or a device that only provides a signal to 1 speaker. Is there anything that might fit my needs that I have not found?
Thank you in advance for any and all help
