Advice on this Cam needed - Lumicron
Discussion in 'Photography Forums' started by leeegglestone, Sep 19, 2005.
  1. leeegglestone
    leeegglestone
    Aug 6, 2005
    24
    Lumicron LDC-618z3
    This is 6mp, 3x opticalm 2x digital. with autofocus
    It is £89.99
    Is the sensor quality ok?? what do u guys think about it ?Ineed advice quick before wednesday when it goes on sale, and i go on holiday the nxt day.
    I notice it only tells u the image resolution up to 4Mp but not 6Mp. Are we looking at all that interpolated stuff?
    Specifications:
    - Image Sensor: 1/1.8" CCD
    - Effective pixels: 6.36 Megapixels
    - Image Resolution: 2288x1720 (4M) , 1600x1200 (2M), 1280x960 (1.2M) , 640x480 (VGA)
    - Focal Length: f=7.7 - 23.1mm (35mm equivalent: 37-111mm)
    - Focus Range: Distance: 40cm - Infinity, Macro: 10cm - 60cm (Wide Only)
    - Self Timer: 3 sec, 10 sec
    - White Balance: Auto, Daylight, Cloudy, Tungsten light, Fluorescent light
    - Shutter Speed: 1/2000 sec. to 2 sec.
    - Shooting Mode: Single, Continuous, Movie
    - Video Output: NTSC, PAL
    - Weight 163g (without batteries)
    - Dimensions: 97 x 56 x 31.5mm
  2. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    My advice would be don't bother - never heard of the company and that usually isn't a good sign. Stick with a well known brand like Canon, Nikon, Olympus, Sony, Fuji, Konica Minolta and the like. Spend a bit extra and you'll actually get better value for money.
  3. stellaman
    stellaman
    should All unknown brands be dismissed out of hand. perhaps for £90 he should have bought it and done a review
  4. jckm2000
    jckm2000
    Feb 26, 2005
    146
    cambridge
    Hi Folks,
    I'm gonna buy one in a couple of weeks to do just that.
    Lumicron LDC-660s ( http://www.lumicron.net/P_SpecDetail/LDC660S.html ) from Tescos, I'll give it a whirl and see. Build quality seems pretty good and it's a nice sized camera, spec looks ok too. I own a fuji finepix 602z and a canon powershot a85 which are both nice cameras but I'd like something smaller to cart around with me at all times.
    If I'm not happy I'll take it back within the 28 days and get a refund. I'll let you know what it's like.
    Jon.
  5. ush flynn
    ush flynn
    Nov 25, 2005
    2,606
    Bromley
    +129
    cant argue with the price as long as that screen holds up. Might find they are made my another manufacturer anyway. Seen a few cameres sharing bodies before
    who'd have thought Centon (jessops exclusive brand) used the same body and some internals as a Contax? well its true :p
  6. bibamus
    bibamus
    Dec 10, 2005
    1,031
    Whitstable
    +44
  7. jckm2000
    jckm2000
    Feb 26, 2005
    146
    cambridge
    Sorry guys, I chickened out and went for a lumix fx8 instead.....
    That Lumicron 660s will have to remain a mystery for a while................
    Jon.
