advice on the B&W CM series!
Discussion in 'Home Cinema Speakers' started by haven't-a-clue, Oct 2, 2004.
  1. haven't-a-clue
    haven't-a-clue
    does the new pioneer VSA-AX10Ai-S go well with the CM series from B&W???
    thanks for your help!
  2. recruit
    recruit
    I have an old issue of the what hifi Ultimate guide to Home cinema and in it the pioneer was recommended to be partnered with B&W CDM series speakers and this was the old AX10 so i don't see much difference so it should work well with them according to what Hifi.
    Probably the best way to see if you like the pairing would be to get a demo if possible.
    John :)
  3. haven't-a-clue
    haven't-a-clue
    thanks john, i'll let you know how it goes!
